I bought a can of GM Top End Cleaner to clean my valves & heads, and now found an older link that slappy, (i think) put up saying to use the liquid instead of the spray! I can see this now as this motor (DOHC) will not run if i pull off the rubber filter to throttlebody hose, and spray into the throttlebody as i had planned to do.
Can i just pull off the vacuum hose on the front valve cover, and the brake vacuum hose on the back valve cover, and spray into those ports to get the job done?
In the other post it says to use liquid and let one of the vacuume lines suck it out of the bottle. If i was to do that & let it go into the front valve cover vacuum port, would the cleaner also clean the rear head?
Thanks for any input....Paul
