I Need Help! Just Replaced Head Gasket
  • I Need Help! Just Replaced Head Gasket
    I just got done replacing my head gaskets and when I went to start it, it idles at 2k and it doesn't go down either. The timing seems to be just fine. and I am fairly confident that everything is tight. Any tips would be great.
    WhiteZ34
    \'92 White Z34 - Custom Air Intake & Magnaflow Exhaust
    Vaccum lines snap ?
    How bout something as so simple as the Idle Air Control valve .. or the Throttle Position Sensor ?
    New member of 200,000 mile club as of May 16, 2005
      Just look for a(some)vac leak(s).
      2004 Grand Am GT 3400 ... I had the right to remain silent, I just didn't have the ability.(Ron White)
        Originally posted by WhiteZ34
        I posted earlier about how I just changed my head gaskets. It was idling at 2k but I found a vacum leak and fixed it. It idles normally now and accelerates just fine like it should. The problem now is that it has a loud clicking sound that increases with acceleration and every now and then the motor shakes a little bit. Any suggestions?
        He fixed that and now started another topic .. found here:
