Error Code 32???
  • #16
    when i got that light i ripped off my egr valve and took it apart and cleaned it and i cleaned out the intake too and then i sealed the gaskets with hi-temp copper silicone gasket maker and it worked fine. usually when you get that light they are just dirty and need to be cleaned.
    • #17
      Cool....
      Well im going to try to clean it first. Hopefully that does the trick. I'm thinking it is just dirty. It seems to only be doing it now whenever I get a fill up. I always run super. But accidently ran cheap gas this last time. I'm thinking that may be whats causing it. Anyways i'm going to go ahead and pull it off today. Also going to remove the intake cause i got a deal on a set of Accel Injectors. Summit has a sale going on them. It has to be dirty cause SES is not on all the time. Or theres a bad injector causing it. Well see...
      \'91 Chevy Lumina Z34
      Soon to do a 3.8L Series 2 Swap
      4T60E 4 speed Auto
      K&N air filter
      White/Gray interior
      • #18
        so, if u have a bad fuel injector, this might cause a code 32 or is that not related ?
        • #19
          It's possible you could... I was reading a post on here somewhere. A guy fixed his son's 3.1L. And they replaced the EGR,IAT all the vacum lines. Bought a new set of injectors and solved the whole problem. Anyways cleaned the EGR and passage on mine. Seems to be alright. I'm going to put new plugs and high output injectors. Get rid of these GM ones. Replacing with Accel Bosch style. Should be pretty cool. Not sure what plugs im gonna run yet. Probably Splitfire.
          4T60E 4 speed Auto
          K&N air filter
          White/Gray interior
          • #20
            look at my cardomain..there is alot of stuff on the egr on page 3 i think. i have how to test it, clean it, and tear it apart
            1st 04 GPG 88-96 mod car show
            L67 Swap, 3.25, XP'd, Custom Headers, 180 tstat, AL103's, 7" K+N, AFC2.2, Rat UDWP & Alt, Walbro,Taylor wires
            N* TB & HP Ported Blower
            PB-13.3@102mph
            http://www.SleeperSe.com
            http://wbodysource.com
            • #21
              Cool....Liked the EGR page...Alot of good info.
              4T60E 4 speed Auto
              K&N air filter
              White/Gray interior
              • #22
                thanks..that is why i did it, lol
                PB-13.3@102mph
                • #23
                  Update for you guys....A year later...LOL
                  Anyways cleaning the EGR and the new injectors fixed it...
                  4T60E 4 speed Auto
                  K&N air filter
                  White/Gray interior
