freeze plug question
  • freeze plug question
    The engine is out so.....Brass or Steel plugs? I guess brass b/c it is more expensive. Also how many will I need? Is there a difference between the head and block plugs? Install methods?
    thanks
    95 MC Z34 Black
    RE: freeze plug question
    Anybody? Well, I guess you just pop em out and install new ones with a special glue.
    95 MC Z34 Black
      Ask the guy at the parts counter what to use on them. I would think some sort of pipe sealant would do the job. If they don't leak, leave them go. They are not actually "freeze" plugs, they just close the holes in the block that are used to clean out the block after casting.
