Water Pump Removal Troubles
  • Water Pump Removal Troubles
    My water pump's leaking and I know it's time for replacement. The problem is, I'm having a helluva time getting the bolts off of the pulley without it spinning and causing a headache even with the belt still on. For anyone that's done this, what procedure did you use to get those 4 bolts off to get to the pump?
    Thanks very much....
    you need to put a large screwdriver between two bolts to hold the pully in place....
    95 MC Z34 Black
      Try a strap wrench. Sears has got them for under 10 bucks.
      2004 Grand Am GT 3400 ... I had the right to remain silent, I just didn't have the ability.(Ron White)
