3.4 up in smoke
  • 3.4 up in smoke
    I have a little bit of an emergency with the petty edition...
    I went to start it, and it just kept cranking and not turning over... so it sounded like it had caught and was going to start, and it made a thud noise almost like a backfire, and smoke came pouring out of the airbox. I opened up the smoldering airbox and the filter is totally shot... and the car doesnt start either.
    I dont know what to do... what do you guys think happened? Im hearing alot about the ICM being a problem from others.
    Or crank position sensor, or wiring. Hope its not internal anyway.
      Thanks,
      It looks like is what happened is this: There is a fuel cutoff switch that is part of the secruity system which is basically fried, and even though i disarmed the car, the "fuel cutoff valve" or whatever never opened fully... so it wouldnt start. I still havent figured out why the airbox went up, though.
        backfired through the throttle body?, can fuel injection do that??? cause that would be a timing issue/stuck valve i would think...
        2001 Mustang GT
        1991 5spd Lumina Z34 - Dead
        1947 4spd International - Dead... Reincarnation pending.. getting close now .
