Problem with Rev limiter kicking in while driving.
  • Problem with Rev limiter kicking in while driving.
    While our cars are working correctly - when you have the car in park and you try to rev the engine a rev limiter kicks and the rpms bounce around a certain limited point.
    This is happening under normal driving circumstances at a much lower rpm than it should. And it only happens under modest acceleration.
    Has anyone run into this problem and is aware of what it is or how to fix it. Or even where to start looking.
    Thanks for any help
    Shane
    shane2195@yahoo.com
    what kind of car is this happening with
    I Like V660s
    Does Chevy make beer
    ~Jayme~
      Im pretty sure its a mechanical issue, not the ecm. Hard to say what exactly, could be fuel pump or filter starving teh engine for fuel, or the plugs/wires.
        This is on a 1993 grand prix
        gtp with the 3.4 dohc
          sappy is probably right
          but i had a thought for a second that the ecm might be getting a bad signal and think you are revving higher than you are
          I Like V660s
          ~Jayme~
            mine does this every so often too.... seems weird.
            btw- had to re register cuz i forgot my pw lol need to reset my sig and all that, im a
              I can reset your PW I believe. Let me know your old name and ill take care of that and delete your new account.
