I get a full charge from the alternator for the first three minutes or so, then if I put the car in reverse or step on the throttle even slightly, the alt stops charging and goes to battery voltage. Tried swapping to another (new) alternator, still the same thing. I've gone over all my wiring and I can't see anything wrong, the grounds on the front and rear of the bellhousing are tight and no wires are touching anything hot. Then it gets weirder. If I shut the car off then start it back up, it's fine again for another three minutes. All this was fine before the previous alt went out.
This is a '95 with a CS-130D.
