Has anyone heard of dropped valve guides in the cylinder heads of the LQ1? Apparently, half of them in my spare engine had dropped. I'm wondering if this is a common problem, or just something that happened to my spare 97 motor.
Unfortunately, theirs don't have the groove for a ring, but the machine shop is going to machine one into the valve guides.
Tim
You won't find any that are already grooved. They can also be purchased rom rockauto. PN VG3112. That's where I bought mine from when I rebuilt my engine. 7 out of 12 guides had dropped on my oft raced 96 LQ1 w/ 200k on it. The new ones weren't really any tighter than the stock ones though. Doing it again now, I would have just tapped the stock ones back in and grooved those.
And the machine shop doesn't have to "machine" the groove in there. It's just a little tool you sit on the end of the guide and give it a couple spins by hand and it cuts a small groove in the guide. They shouldn't charge you much for that. I had my own tool from doing Mitsubishi V6's. Those things were horribe about dropping guides.
But to ramble on here, I do think it's very common on an LQ1. It seems there's a lot of completes about smoking/oil consumption and it's generally assumed it needs valve stem seals (which usually never get done). My guess is they need new valve stem seals because they fell off of the dropped guide. If I was to ever have another LQ1 apart, I would go ahead and snap ring my guides to avoid this headache, even if they were all still in place.
