91 Lumina Z34 Problems
  • 91 Lumina Z34 Problems
    Hey all! Just picked up a 91 Lumia Z34 for $500 and I dont want to sink a ton of money into it, but I want it to run right.
    Right now I live in MN and its been getting colder and colder. When I start the car the engine idles high and bounces off the rev limiter. It does this till its warm. I've sprayed carb cleaner all over the vacuum lines and it doesnt change anywhere so I am sure its one of the sensors. Not sure which one.
    Now, I'm not very mechanically inclined so pictures would do me TONS of help if you could.
    I was also searching for the distributor o-ring fix, I cant seem to get the search function to work on the forums.
    I am leaking lots of oil from the car, but only when its off and its leaning towards the passenger side. If i park leaning towards the drivers side it doesnt leak oil as bad. I'm guessing its either the Crankcase seal or the famous distributor o-ring.
    Any pics of either of these things would be a HUGE help!
    Thanks!
