Okay, I'm going to try to explain everything that has been done to this car and where we sit now.
95 GTP, engine threw a bearing. Lucky for me I had a spare 96 LQ1 with harness, ECM, etc. Me and my buddy built it up from the ground. All new gaskets, new CPS, TPS, plugs, wires, timing belt, tensioners. We installed the engine into the car, and got it to start. It wouldn't really run without a little throttle. After one successful run of about 20 seconds or so it wouldn't start again. Starter wouldn't even turn over.
So now we wait until the following day. Try again, car starts but dies after a few seconds, car will turn over again but not start and you can smell gas. Pretty sure its flooding. Then the starter wont turn over again. We have some electric gremlin.
Yesterday, try to start again. Starts first time, dies after a few seconds just like the previous day. Then we smell gas and it wont start. We decide to track down electrical gremlin because starter wont turn again. Well, alternator positive rubber boot isn't on and the metal power steering line is touching. Fix that up. Now it will turn over each time. But it struggles to start. We can get it to consistantly start with WOT, but it wont go above 1k rpms and dies after a second or two.
Not sure if its not getting enough gas, or maybe that the fuel pump cuts off after car is running? Could we have fried the ECM? MAF? IAC? Not sure how to check FPR, its not spitting out gas. I'm kind of at a loss, was hoping for the 60degree Gurus to give some advice.
