It's not very often that I find myself in a position of not knowing the cause of an engine irregularity but I have now. The engine is seeing a stumble/miss at near all rpm (but it's most noticeable at speed when the TCC is locked up and the converter can't absorb any irregularity from the engine so you feel the problem.
My car sees very little use and last July a problem reared its ugly head that saw an intermittent stumble/miss begin to occur. Seeing as the plates on the car soon expired and I did not renew them, the car basically sat until four weeks ago when I pulled the car out of it's storage and once again I am facing this problem. Miraculously the car passed it's emission test. I've dived into the problem. My scanner reveals no codes at all. It's not emission related. At first I thought the problem might be a sticky line pressure valve in the trans TCC circuit that is causing the TCC to lock & unlock repeatedly seeing as the TCC solenoid is doing what it is supposed to do & is not to blame. Then I noticed that I could actually hear the tailpipes sputtering & missing as the car is driven at a relatively mild speed. This led me to think that I might have a ICM situation, pulling the plug wires at idle told me next to nothing except that all cylinders are firing. So I went to the trouble of getting the ICM & coil packs off the block (wonderful job) and replaced the entire assembly with a known good set. Problem remains. Next stop...Fuel Pressure diagnosis...
I plugged in a fuel pressure gauge to the rail and as it should be the rail is seeing 50lbs at idle so this leads me to think the the FPR hasn't failed. At this point there is the obvious left and that would be the injectors. I have discounted them because if an injector (or all) were miss firing then this miss/stumble would be all the time especially at WOT but that is not happening. It happens when the throttle is feathered, or just slightly off the throttle. So now I'm wondering what I have missed, as stated the scanner reveals nothing out of the ordinary. All one sees on the scanner screen display with regards to mixture is *lean* when on the highway, not *lean/rich/lean/rich* just lean. This makes me think that the ECM would cause this. So, if anyone wants offer any possible solutions...I'm all ears.
Steve
Steve
