Hey all,
I've got a '92 DOHC/5-speed with an ongoing problem that I think is IAC related. When I reset the ECM, the car drives beautifully. But as the miles rack up and the computer thinks it is dialing itself in, drivability starts to deteriorate and it develops some jerkiness. Like it lets out a jerk when I let off the gas, or the revs fall off too fast and shifts are rougher than they should be.
Now I've been troubleshooting this from a lot of different angles for several years, particularly on the fuel and vacuum side and I've ruled those out. So often I've had more pressing problems to solve with it that a minor drivability issue like this is pretty far down on the list. But today it was especially badly behaved, and got me thinking about the IAC follower in the programming. Even though I've replaced the IAC a couple times on it, it might need calibration so the follower reacts properly. I have the GM service manual, and it says that the IAC has to be recalibrated with a Tech1. Has anyone figured out how to do it WITHOUT a Tech1?
