Upgrading the 91-93 3.4 DOHC to 94-95
  • Upgrading the 91-93 3.4 DOHC to 94-95
    Hi,
    I've a new 91-93 3.4 DOHC engine manufactured in 1997 with the 94-95 camshaft equiped with the relucter surfaces for sensor interfacing. I will be instaling the camshaft position sensor over the flat surface portion on the LH cam carrier. I'll need drill a hole in the exact position in which the sensor is suposed to be.
    Any tips and helps will be apreciated previous to this delicated labour.
    Thanks in advance,
    Denis V.
    i would have a machine shop doit unless your are a confedent driller... I have heard a few guys on here talking about doing it but not heard if they did it or just ran a used 94+ cam carrior.
    S
    Shane "RedZMonte"
    1992 Lumina Z34-VIRGIN (RIP)
    1992 L67 Lumina Z34 (SOLD)
    1990 Turbo Grand Prix (SOLD)
      Hmm. Good point.
      Main difference with the machine shop is that they uses a "fixed on table" drill. I could use a "hand supported" drill only with its hand movement risk on driller process. I will think about.
      (The harmonic balancer will be replaced too and a 24x crank sensor will be installed in the front cover by drilling 2 littles holes for CPS bolts).
      Thanks,
      Denis V.
