need to kno dohc fkly wheel torque specs, and the clutch cage specs
flywheel torque specs
Flywheel to Crankshaft Bolt..............................83 N.m (61 lb. ft.)
Clutch Cover to Flywheel Bolt.(pressure plate)...20 N.m (15 lb. ft.) plus 30 degrees
And you can bet those are the correct specs because I got them out of my factory shop manual for my 92 LuminaThis for your 93?
From what I have been told, 93 5 speeds are some of the more rare car on the already rare 5 speed list.-60v6's 2nd Jon M.
