Ignition key lock cylinder 95 lumina
  • Ignition key lock cylinder 95 lumina
    my ignition cylinder seems to be loose its sticks out about a 1/4 if an inch from the column housing and seems to be spring loaded is this normal.
    Yes, the lock cylinder does have a spring action, but it should only push in about an eighth of an inch to rotate.
      tks fiero thought i have to re and re lock cylinder,also do u know how to bypass the vats system
