Ok so my valve seals leak like a civ, and looks as if my rear HG is starting to seep a little.. Im dreading the day i do this but i want to know a few things...
1.) Head set, what brand? Found a full Head set + Bolts from Felpro, Looks to be my best option... Any other ones to consider (keep in mind im turbo)
2.) what timing belt? can i get a kit with tensioners and all or just piece together?
3.) What should my compression be roughly? im going to check the compression 1st so i want to see if i need a full build or just a head gasket/t-belt
4.) Timing Chain, should i replace it with everything? again 150K miles turboed and daily beat.. any recomendations on timing chain?
Thanks in advance
Thanks in advance
