TIMING GEAR WIGGLYING AROUND!!!
  • TIMING GEAR WIGGLYING AROUND!!!
    i opened up the timing inspection cover and started the car up...the noise i was hearing wasnt the PS pump or any of the accessories but the damn gear of the timing belt...it looks as though they did not put the lockrings on the cam gears or something cuz one cam is really spining NOT IN A CIRCLE...ima post a vid up in about 1hr so for now, wat do you think it is? Bent/stuck valves? GRR!!
    UPDATE: here's the vid
    theres the movie of it...
    \"Pree\" - 93 Grand Prix SE - 3.4L Twin Dual Cam
    - FFP UD Pulley - FFP Chip - 8mm Taylor Wires
    - 160* T/stat - Dual 40 Series Flowmasters
    - Hi-Flo Cat
    15.2@95mph - GTECH P/B
    http://home.rgv.rr.com/tjperformance/Cap0005.mpg
    i'd be going back to that shop real quick and have them fix that. Wit it wobbling around it might have damaged the gear and cam itself. Valves I don't think so
      wat could be making it wobble though?
      - Hi-Flo Cat
        I can't tell from the vid, but does the whole gear wobble or just the bolt? Is the bolt tight?
          it looks as just the bolt though the gear wobbles some...i know there are suppose to be lockrings on the 93 setup but looking at the cam, i can not see any. Will not putting the lockrings back on affect it? Were are the lockrings located?
          - Hi-Flo Cat
            Without lock rings the gear will wobble. Short of taking it apart I see of no way of telling what is wrong.
              I hope its the gear and not the cam itself or the carrier. Hard to tell but that doesn't look healthy at all. If you can get the bolt off and then the cam gear moves...you have to retime it. I would use a cam flat tool to make sure the cam doesnt move and then remove the bolt and see what the gear does. Hopefully its just the lockring.
                i made the hold down tools, yeah!!
                Here are the hold down tools i made...out of wood! ANyone see any probs i might run into wit this setup?
                [img]http://photo.starblvd.net/~grandprix93gtp/3-2-1.jpg?i=1068192231&pw=*2593F80AC0C[/img]
                [img]http://photo.starblvd.net/~grandprix93gtp/3-1-5.jpg?i=1068192123&pw=*3403F80AC33[/img]
                so i leave the belt on the gears, spinn the gears/belts till the cam flats are up and just bolt down the cam hold down tools right? then just untighten the bolt on the cam gear, inspect the bolt then remove lockring? Wat is the UNIVERSAL 3 PRONG PULLER USED FOR? TO pull the cam off the camshaft? Thanks for everyone's help thanks!
                - Hi-Flo Cat
                  I don't think you should use wood. If you put any torque into those at all there would be deflection in the wood which would cause the timing to go off a few degrees on the cams.
                  I made mine from 3/4 steel stock, and I advise you do the same.
                  I'll get a pic of mine when I get home.
                    yeah they were more prototypes than real things...
                    now i can show the guy at the machine shop wat im talking about...lol
                    i mentioned keystock and he thought i was talking about "spare keys"....
                    - Hi-Flo Cat
