Ok so i got my car all back together... drove the the gas station put 5 gal in...
1.) car stumbled and stalled when i put into gear... restarted and reved up a little, put into gear and stalled again... did it a 3rd or 4th time and finally it started and stumbled but got going.. then once its going it was fine, drove and idles fine... (i think EGR... previously unhooked... now hooked up)
2.) P0172 code after driving from gas station to work... WBO2 read 14.5-15.5 crusing and 10:1 at WOT... its been running recently 11:1 at WOT but for a long time it was 10:1... It is ALOT colder today then it has been in a while.. I googled the 172 code and got everthing from clean your MAF to vac leak. If the EGR is opening i guess that could be causing the O2 to add more fuel.... Hmmm i will try unhooking the EGR now..
S
S
