I have replaced almost every sensor in my z34 and it still has problems staying running and stalling when it comes to a stop and going around corners and just slowing down to a low idle it dies every time when its in park it idles just fine for about 10 to 15 minutes and then dies. I just read on another forum about phantom stalling and it matches my problems exactly it also said that I could find some kind of hard to find injectors on this website that will fix my problem if you agree or know where these injectors are please help me out thanks so much.
93 z34 with problems. PLEASE HELP
Have you done proper testing? Fuel pressure, vacuum...etc. I would be more worried about that first. And as far as almost every sensor...which ones have you done and which have you tested? Did any fail tests or are you just throwing parts at it? I'd also check the the catalytic if it has one still. You will get more responses if you post this in the DOHC Forum.
Originally posted by Mole1333 View PostHave you done proper testing? Fuel pressure, vacuum...etc. I would be more worried about that first. And as far as almost every sensor...which ones have you done and which have you tested? Did any fail tests or are you just throwing parts at it? I'd also check the the catalytic if it has one still. You will get more responses if you post this in the DOHC Forum.=Joel=
Originally posted by jdellinger1980 View Postlast of all I thought I was on the dohc forum and if not which one is it.-Brad-
A lot of people don't read the member's forum, so asking a question in there usually doesn't get much coverage. Having it in the appropriate will result in a better chance of someone will read and be able to answer it.-Brad-
I experienced the same problem with my 3.4 Cutlass, I did the IAC, MAF, to no avail, turned out that I had a lazy O2 sensor that wasnt tripping a code, If you have access to a scan tool I would watch the O2 (upstream) for slow readings, I put that in the car was fine... Or you could also just pelace it considering it probably older than dirt anyway, I had the same prob, this is my fix, I am also a trained technician, so yeah funny I know but try it. I would venture to say I am 75% sure its your prob
thanks
Thanks for the reply This thread has been up for a while and Ive had many solutions and someone told me about phantom stalling and told me I had to put a bigger injector in and I did this and everything improved for about a month and now it is starting to do some of the same things again. So my question is where is the o2 sensor at and do you happen to have an idea of how much one cost. I can do pretty much any of the work that needs to be done to my car I just need to be pointed in the right direction, thanks for the response.=Joel=
~$50 and it's in the rear exhaust manifold. The O2 sensor reads the exhaust to tell the ECM how the engine is running, so you really confused the ECM by putting larger injectors than it was calibrated for. I would put the originals back in, change your O2, pull the ECM fuse (for ~30 seconds) to reset the ECM and let it relearn.-60v6's 2nd Jon M.
I also forgot to add. Our DOHC injectors have a different spray pattern than normal pushrod/ohc engines.-60v6's 2nd Jon M.
I think i still have my stockers in the garage... Let me look when i get home. I will sell them cheap... they came out of my '95 Z34 w/ ~90K miles. I swapped them out with the turbo setup. they worked flawlessly untill the day i pulled them. I changed my fuel filter and ran BG44K on a rutine basis so they should be perfect.. I would suggest new O-rings when you put them in.
SShane "RedZMonte"
1992 Lumina Z34-VIRGIN (RIP)
1992 L67 Lumina Z34 (SOLD)
1990 Turbo Grand Prix (SOLD)
You really should check the fuel pressure, and pressure regulator. My Regulator failed and the fuel traveled up the vac. line, cooked the map sensor. The fuel was pooling in the intake and doing very similar stalling. Also mine had a difficult time starting (Duh- wrong fuel pressure and tons of raw fuel...) Just wondering if you were also having that issue.sigpic
Fiero gt 3.4 DOHC turbo forged bottom end MSII
94 Ranger 2.3 turbo t5 (DD)
