Ok... was replacing my injectors notice that the EGR tube felt loose so investigated and found to be broken in several places...ok so i figured not to bad remove the bolt and replace it. However bein the location sucks it was a lil hard , than thing changes drastically as i was loosing the bolt the BOLT broke off leaving bout 2/4 of inch stick up... after doin that i figured id call it a day considering ill be waiting 5-10 days for the TUBE from GM..
my question is....how the hell do i get that stud out with out breaking it further down on the manifold? I sprayed PB blast on it twice hopefully to soak it in. Any and all suggestion would be greatly appreciated. Doesnt it figured that Domestic vs Import FWD challenge would be this weekend at are local drag strip. Guess ill be a specator again this year.
