it sticks out on the passenger side from the fuel injector cover (the DOHC plaque on the motor)... the thing that looks like a bigger tire filler? lol im pretty sure thats what it is.
Huge Power Loss! Need Help...
Originally posted by robertisaar View Posti don't know where the schrader valve is on a 3.4 fuel rail... but that is where you would test fuel pressure...
the "rust" color alone is normal. are there any deposits built up on it anywhere and what color are they? and are the electrodes looking completely normal or are they looking somewhat melted, or chipped or do they have little specks of metal on them?
is the rust color consistent all the way up the insulator?
DG
then those are fine. change them if you want, but they still have a lot of life left...
EDIT: from bruce plecan (grumpy from TGO... RIP)
White leaning to beige Good WOT mixture
White leaning toward black Momentary rich spot
Bonding agent cooked out between porcelain and center electrode, or the side electrode gets a metallic green/blue hue Plug range too hot, or temp too high in combustion chamber, possibly too much timing
Heavy black flakey deposits Too much fuel
Black glossy deposits Oil
salt and pepper flecks/fly turds/tiny metallic balls on porcelain Detonation. The flecks are little bits of piston
Fire ring (tan spot/ring) If high up on porcelain timing is probably good. If it's near the tip you might want to try a little more timing
Corners rounded off center electrode (newish plugs) lean/too much timing. Or just normal wear if the plugs are old
Black spiderweb traces on center electrode Usually only on early HEI systems, a better spark box or maybe low resistance center button will fix it.
Pools/spots of odd colors Fuel splashing, fuel additives. Can vary with brand. Manganese leavs a pink residue which can be a ground path and cause misfires.Last edited by robertisaar; 10-06-2009, 08:19 PM.
Just did a fuel pressure test.... 40 PSI at Idle and 48 PSI under load
Seems about right to me. So I think its safe to say the fuel filer and pump is good.
I am wondering if the injectors could be bad.... OR because the fuel pressure did not bleed off and the plugs look tip top,... the injectors are good...
I am stumped!
Dan
What brand plugs are in there? If Bosch get em out asap!! Put AcDelco in there. I fouled 3 plugs at once and they were Bosch. Bosch does not make a good plug for the W platform. That could be your problem right there.Robert
New Rebuilt 3100
New Rebuilt 4T60-E
Exhaust
Drilled/Slotted Rotors
White
3" Magnaflow Catback
90 Pontiac Turbo Grand Prix
5 Speed Swapped
127,000
Spec Stage 3 Clutch
230,000 mile Getrag 282
Emissions Deleted
Brand new Engine 1,000 Miles
Fully Custom Built car
I'd go with the FPR or the MAF sensor being the problem. I've actually had a problem that was VERY similar before (and very annoying), but I don't remember exactly what was wrong. The FPR can fail and begin leaking fuel into the intake manifold. Normally, it causes hard starting, but once the car is running everything is okay. IIRC, when I had MAF problems they were similar to what you are describing.
325 whp 350 lb-ft
Originally posted by robertisaar View Postif you unplug the MAF and nothing changes, what does that tell you?
And I'm not even a MAF or OBD2 guy.-60v6's 2nd Jon M.
And I'm not even a MAF or OBD2 guy.i hate the both of them. i just know that if you unplug something, and nothing changes, it wasn't working correctly, if at all, in the first place...
Originally posted by robertisaar View Postneither am ii hate the both of them. i just know that if you unplug something, and nothing changes, it wasn't working correctly, if at all, in the first place...
That's what I've always believed too-60v6's 2nd Jon M.
Wait a second though... Won't the MAF resort back to the base tables when unplugged? Lets say the car is running correctly... if I unplugged the MAF it should run slightly worse, but it should still run.
Now if the maf was working improperly, when I unplugged it, the car would resort back to the preset base tables, and should run better, but not great.
Am I on the right track here... or are we facing an MAF problem?
Dan
