Originally posted by roho94Z
View Post
z34 goes straight to 3 grand(rpm)
not black smoke, grayish blue haze, does not smell like oil. okay whats the fpr and uim my manual really doesn't tell me where half this stuff is. just a picture and guesstimate the location94 Z 34 165000 on the ticker, 3" cat back into dual Flowmasters,air box MIA, K&N sucking it up, auto
FPR=Fuel Pressure Regulator.
UIM=Upper Intake Manifold.
obviously look around the fuel rails for the FPR(no pic, i don't have a 3.4)
and the UIM is the pretty self explanitory...
and oil usually burns a light blue color
fuel is black
coolant is white
doesn't have to smell like oil to be oil. the cat usually absorbs most of the smell/smoke too, so thats something to consider...
my vacuum line was squished under the upper intake, thats the huge gray thing behind the black 24V DOHC plastic cover, and the rear valve cover. it wasnt cut, just squished. once i moved it, the problem was fixed. the fuel pressure regulator is the thing on the transmission side of the engines fuel rail ( the thing all the injectors are connected to) and its a round thinggy, i dunno, the only vacuum line that attaches to the fuel rail anyhow... so its a tough one to miss when youre looking for it, easy to squish if youre not.
trust me, if its a stupid mistake a guy could make while fixing his car, ive made it.
best i have is a picture with the upper intake off, and the fuel rail is out, but its looking at the side of the car where the pressure regulator is.
there is also a metal vacuum line that is bolted to the fuel rail (not technically part of it) that is for the transmission this one is obviously a little tougher to squish. lol
aint i stoopid, wrote that in my early post. double bourbon straight up. 02 was changed when the uim and lim were changed. but the cat. is original, and it rattles. could it be creating this mess. the fpr is under the uim so if the line is pinched i'll have to tear 'er down94 Z 34 165000 on the ticker, 3" cat back into dual Flowmasters,air box MIA, K&N sucking it up, auto
it takes me about 20 mins to take off the UIM if i have to dig through my little tool box to find everything, if all of the tools are laid out, 10 mins, no prob!! lol mind you its just a pain in the ass looking for a 10 and 13mm socket in a mess of others.
recently i purchased a few sets of colour coded sockets on holders, so maybe i can get my times even faster. lol
The bigger problem with the line being pinched isn't the fact that the FPR isn't regulating pressure, it's that the plastic line creates a huge vacuum leak since the UIM and LIM can't make a good seal trying to be mated together with the vac line in the way and there is air being ingested that the TB isn't controlling. If you think those LIM ports are big, you should see the ones on the 96/7 manifolds.
ahh, now it makes sense. but shouldn't starting fluid anywhere near it have made it rev even faster?
EDIT: JESUS TAP-DANCING CHRIST! its no wonder why the motor can't make any torque under 3000RPM... but what a healthy pull it gives from 4K and onward...Last edited by robertisaar; 08-26-2009, 10:59 PM.
Isn't it a thing of beauty?
And yeah, starting fluid would have made a huge change in the way the engine was running, and I would imagine if it were a quiet engine, you would hear the leak as well.
