95 GTP sounds cammed
  • 95 GTP sounds cammed
    ok my boss just bought a 1995 GTP with the 3.4 DOHC for his doughter after a 80 year old totaled out his 1995 SE. it runs like a raped ape and will break loose going into second. but at idle it sounds like it has a huge cam any ideas why is this normal?
    i do not know mutch a bought these engines so i figured i would ask here
    if it has torque it probably has a cam!! hahaha mine doesnt have ANY torque as far as im concerned.
      if it sounds like it should be running on something other than gasoline, look for a vacuum leak...
      both the monte and the GP sound almost like top fuel when i pull the brake booster vacuum line off to pour some good old seafoam in to clean out the motor...
      LQ1s don't start making a lot of torque until 2500/3000. a bigger cam would make it even worse, since it would shift the powerband up even higher...
        hmm ya this thing actualy has bottem end tourqe to it lol.
        he said it sounds like my GP witch has the XP cam for the L67.
        i guess i will look for a dry rotted hoses
        here is a vid of my car
        please comment, rate, and subscribe if you liked this :)car has a top swap 3" DP 3.4" pulley zzp pcm with some fine tuning done to it. stock cat back no KR
          thats about how mine sound with the line pulled, except without the gravel/flatulent exhaust noise the 3.8s make.
            no argument that the 3.8 sounds like butt lol
              i <3 the way my car sounds with stock exhaust - cat replaced with resonator. this winter its going to be something else though... all for another thread.
              when you find out what this 'problem' is, let me know. i wouldnt mind breaking mine aswell.
                will do
                  Could be the cam timing itself. Being that it has separate intake and exhaust cams means that if either is out of time the overlap between the two has changed. A lot of overlap can make the engine lope. The car could have intentionally modified cam timing as well, the -13* on the exhaust cams is good for a power bump and does cause the engine to lope... the only thing that doesn't fit the bill is that you say the car has seeminly more bottom end torque then it stock and that is something that does not happen with the -13 timing.
                  I'd do what others say first and check for vacuum leaks. Spraying carb cleaner on the intake gaskets and listening for a change in idle is a good indicator of a bad gasket. You can also go ahead and replace the intake gaskets and change the plugs/wires as a tuneup on a 'new' car. The gaskets are cheap for the 91-95 motors and easy to change.
                  1994 Corvette
                  LT1/ZF6
                  2006 Dodge Dakota 4x4
                  3.7/42RLE
                    well the car just had the timing belt replaced aperantly by the local dealer . (he found a recepit in the glove box dated last month) so i think the cams would be factory timed then. he is going to change all the vac lines just to make sure with how old the car is some could be dry rotted
                      hmmm more torque would be nice... might be going to the rocky mountains this weekend, high altitudes, low oxygen and no low end power already dont sound like fun.
                      anyone ever try an electric supercharger?? might be what i need to suck in more air.
                      -lol why dont they make an electric turbo?
                        the car is also an auto no idea if that makes a diffrence
                          do NOT touch an electric anything.... they "create" boost, something your MAP sensor can't read. although you're going to be in a low-altitude area and wouldn't be able to move enough air to make boost, you're going to restrict your intake even further, meaning the "blower" will need to be running at all times.
                          about the only electric power adder i've ever seen thats done anything is the e-RAM, that thing is a beast, pulling like 800watts(smallest model)...
                            Originally posted by 01GPGT View Post
                            well the car just had the timing belt replaced aperantly by the local dealer .....i think the cams would be factory timed then.
                            I'd hope so, but honestly I don't trust anyone but myself when it comes to timing the engine. The LQ1 requires special tools and some dealers probably haven't seen this motor in years. Some techs may have never done it before. I'd almost put money that the belt was the issue since it was recently timed.
                            1994 Corvette
                            LT1/ZF6
                            3.7/42RLE
                              ^X2, its a very good explanation....
                              and for reference, i don't trust anyone doing anything to any vehicle... except for alignments, but thats only because i don't have the equipment for it.
