So im having some annoying little issues and i thought i would ask to see if you had some ideas... keep in mind my car is kinda wacky. 1995 Monte Z34, Trunk mounted Battery (optima yellow top.... Honda size), 1996 Z34 Engine harness, Rear disc conversion.
all of the issues im sure are related..
1. intermintant starting on 1st attempt.. it will make a partial crank over and then stop.. then i turn the key to off and on the 2nd attempt it fires up, and sometimes it fires right up 1st try.. when it does this, my radio presets/time clear and i have to reset them. it will allways crank over and start on my 2nd attempt so i wouldnt suspect the starter sollinoid..
2. about 70% of the time my dash lights are dim at night as are my head lights. when this happends the ANTI-Lock light comes on. Sometimes it will after running for a bit everthing will become bright again (headlights, dash lights) and sometimes it comes on bright when i start the car and be fine (rarely).
Im thinking it could be a couple of things... A.) the power wire i used for the OBDII swap wasnt large enough to feed the interior harness B.) Not enough Battery power (honda size in the trunk) C.) alternator is starting to act up....
what are your thoughts?
Thanks in advance,
Shane
Thanks in advance,
Shane
