I posted a while back about having serious problems with my 92 Z34 Lumina (auto). I replaced quite a few parts including the ignition module and it started running nearly right. Here are my problems; its running rich to the point where you can smell it at startup and shutdown, gas mileage is nothing like it used to be. Also, whenever in overdrive the car suffers a pretty severe spark knock, there is nowhere's near the power it use to have and at 4500rpm I have a flat spot. On occasion the car will spit and sputter but it only does it when the check engine light comes on (which is only for seconds at a time). I hooked a scan tool up to it and found out after warming up for 15min or so it stops running rich but still doesnt enter closed loop mode. And on occasion the idle will oscillate between 700 and 850rpm.
The engine has less then 46000 miles on it
Brand new as of september of last summer:
-Plugs and wires
-Full timing kit
-Water Pump
-All new gaskets
Brand New as of the past 3 months:
-PCV valve
-Ignition module
-Coolant temperature sensor
-Replaced 1 out of 3 ignition coils
-Fuel filter
-Intake manifold gasket
Also the entire fuel rail and all injectors were just taken apart and cleaned thoroughly. All parts that were put on the engine have less than 6000 miles on them. I was told that the hydraulic tensioner might have failed causing the cam to jump time and is not running "retarded." That was from what use to be a GM tech. I bought a new 02 sensor for the car and will be installing it soon. Does anyone have any ideas for me?
-Plugs and wires
-Full timing kit
-Water Pump
-All new gaskets
-PCV valve
-Ignition module
-Fuel filter
