Just when I thought it was running great!
I developed a mystery coolant leak. It appears to be coming from the timing cover area and I can't quite pinpoint it. Cold engine doesn't leak and a hot engine drips. If I get on the gas hard when I come to a stop I get coolant steam coming out of passenger hood louver. It isn't the steel heater core line and it is also not the waterpump. I pulled the timing belt cover and there is A LOT of moisture on the inside of the covers. I suspect it to be the freeze plug in the rear head - I replaced both heads a few months ago and since then the front head lost a freeze plug so that leads me to believe the freeze plug in the rear head is ready to fail/pop out.
Is there a downside to using the rubber plug with the tightening bolt? I can access the plug with the timing belt tensioner plate removed and I think I can install the rubber kind but if they are prone to failure I'll pull the head.
