Hi Guys,got a strange idle issues on my 95 lumina 3.4 dohc,work done so far is sparkplugs change,pcv valve tranny oil and filter,cleaned the maf sensor.Now when i start the car the revs go up to 2000 rpms and within a second drop to 1000 rpm,and at 1000 the revs goes up and down to about 1200 back to 1000.Also after a long drive after letting the car cool down,when i go to start it does the same as above but instead of staying at 1000 rpm it does shuts off.Any ideas why.Sorry for the long post.
wierd idle issues
Originally posted by robertisaar View Postdoes it throw any codes? and that was not in the least, a long postLast edited by stoneymonk; 04-19-2009, 10:36 AM.
How did you clean the MAF? I have heard of idle issues after people have cleaned the MAF before-Brad-
Good man. That stuff ain't cheap (I just bought a can for my truck), but at least it's the right stuff for the job. I've heard from people that used either brake parts cleaner or carb cleaner (can't remember which) that their sensor was fine after cleaning, but I would rather not take the chance.-60v6's 2nd Jon M.
Originally posted by robertisaar View Postcarb cleaner leaves a very fine lubricant after it dries, brake cleaner is nothing at all. i would go with brake cleaner working better
I like how the can says that you gain something like 4-10hp after using it. So if I clean my MAF 10 times, that's 100hp, right? It's funny how they don't mention on the can how you don't actually gain it, you just get back what you lost from a dirty MAF.Last edited by pocket-rocket; 04-21-2009, 01:28 AM.-60v6's 2nd Jon M.
Originally posted by pocket-rocket View PostBut stuff he has is made for MAF sensors, so it would be better yet.
Pull the map sensor and attempt to start does it start?, reconnect MAP and start up and pull it while running, what does the engine do? reconnect while running, what the engine do?
Pull the IAC while running, rev it up let it go to idel what does the engine do?I am back
Mechanical/Service Technican
