valve covers on a 95 dohc lumina
  • valve covers on a 95 dohc lumina
    Where are the valve covers located and how hard to replce gaskets.
    the front valve cover is right on the top front of the engine.. its cake to replace.. the rear valve cover is under the intake manifold so you need to remove the upper intake manifold. its easy just takes a little time if you have never done it. the coolant hose going to the upper intake is probably the hardest part to unhook and if you have a long pair of needle nose its pretty easy. a few 10mm bolts, couple hose clamps, couple vac lines and its out.
    S
    Shane "RedZMonte"
    1992 Lumina Z34-VIRGIN (RIP)
    1992 L67 Lumina Z34 (SOLD)
    1990 Turbo Grand Prix (SOLD)
      Thanks for the instructions,you wouldnt happen to have any pics?
        look in the pic section of the forum. there are some pics.
        S
        Shane "RedZMonte"
          S
          no offence or any thing,but just cut the frickin hose and replace it.nothing wrong about putting new hoses on a car that is probably 10 years or older.
          besides that,that hose is a pain in the rear to disconnect
            Thanks for your replies,as for the pics did a search but couldnt find any.Also is there any info on luminas that came stock with console ,floor shift and rear spoiler.?
              what kind of info?
                the thingy with holes in it(where the spark plug wires go. below the red cover in the pic is the valve cover
                  Originally posted by savannaz34 View Post
                  what kind of info?
                  How many were made,the only one i have seen is the one i own.
