Hi. I'm new on this site...my 1995 Monte Carlo Z34 has been doing something odd...
It will get very hot and then cool down during normal driving; My temperature gauge swings hot and cold constantly. This happens usually 5 or 6 times within 5 minutes.
It seems to be affected by the outside temperature and when I use my heat. When it is cold outside, and I am using heat on setting 2 or 3, it will heat up until the point where the HOT light comes on, but the light stays on for less than 10 seconds, and then the gauge swings back down to normal temperature, in which the gauge sits around a quarter of the way from cold. But when it is warm out, and I am not using heat, the highest my gauge will go would be about 3/4 of the way up.
I've been asking around for opinions and most people say that the gauge is bad, but once when it was getting hot, I used a laser thermometer to check how hot the engine actually was, and the gauge was correct.
Oh we also replaced the thermostat back in November because it was doing this, but it would just overheat (the gauge never swung back down.)
any opinions? I am a member of mymonte.com, and i posted this same thing on there but this site seems to get more traffic. thanks
