'91-'95 coolant outlet
  • '91-'95 coolant outlet
    Damn! I just received second incorrect coolant outlet I've ordered off the web. Wish they'd put pictures with the listings.
    First I get a cast iron one that looks like it's for a small block Chevy. Next from GMPartsdirect I get the tubular steel one that bolts to the front of the manifold at the thermostat location.
    I'm trying to replace the aluminum part that bolts to the water pump. Does someone have the part number for it?
    GM PART # 10130907
    CATEGORY: Engine Coolant Pump Inlet
    PACK QTY: 1
    CORE CHARGE: $0.00
    GM LIST: $14.89
    OUR PRICE: $8.49
    DESCRIPTION: INLET-WAT
      Thank you. It's on order.
        no problem, i bought one not too long ago
          Engine Coolant Inlet Housing
          Originally posted by patgizz View Post
          GM PART # 10130907
          PACK QTY: 1
          CORE CHARGE: $0.00
          GM LIST: $14.89
          OUR PRICE: $8.49
          Is this part still available? I require Qty. 1 ASAP
          Thanks,
          morrayp
            morray, you revived a post that was dead 5 years ago... are you trying to imitate no_doz?
            and if you put that part number into the search box of GMpartsdirect.com, you'll probably find it. i just did it and the price at the moment is 13.43.
