Question, there's a small pin hole in the indention slot around midways of the lifters, does the hole of the lifter need to be in the position where the open area of where the lifter goes in the cam carrier to get good oil exposure? Holla back.
Correct lifter placement on a 3.4
I just did this today... they spin in the bores so no issues with lining anything up. Nothing on the lifters themselves spun though? By center tab I think you mean the part that contacts the valve stem? Mine definitely did not move independently of the rest of the lifter.
Just a heads up, as skeptical as I was in believing the GM manual, using fuel hose forced between the lifters really does work at retaining them while installing the cam carrier. I didn't have a single one drop out.1991 Grand Prix GTP LX9swap/Getrag 284 --- SOLD =(
1994 Corvette LT1/ZF6
2006 Dodge Dakota 4x4 3.7/42RLE
Originally posted by jmgtp View PostJust a heads up, as skeptical as I was in believing the GM manual, using fuel hose forced between the lifters really does work at retaining them while installing the cam carrier. I didn't have a single one drop out.-60v6's 2nd Jon M.
