I'm working on a friends 97 Monte Carlo with the 3.4 DOHC. This is my first time working on one of these engines. The car is showing symptoms of the cam timing being off (poor running in all conditions, raw fuel dumping into intake manifold, fuel in vacuum lines, no codes other than multiple cylinder misfire, plugs are coated in fuel). I'm slowly starting to understand how the cam timing procedure works, however I need some verification. I took some pictures of how everything currently lines up hoping that someone can tell me if the timing is correct or not:
Crank pulley at TDC on EXHAUST stroke for #1 cylinder.
Cam lobes on #1 cylinder are facing down opening valves (exhaust stroke)
REAR bank cam flats are facing up and parallel.
Everything seems correct so far.
Now we spin the crank pulley 360 degrees.
Crank pulley at TDC on COMPRESSION stroke for #1 cylinder.
(I know in the pic it is slightly off)
Cam lobes on #1 cylinder are up away from closed valves (compression)
Now here is what I don't think is right. FRONT bank cams are NOT facing up and parallel. Aren't they supposed to be flat once you spin the crank over 360 to get #1 at the TDC compression?
Am I correct in saying that this timing is off? Thanks.
