Hi gang...I have a 1994 Olds CS with the DOHC and it idles like CRAP. It has a miss that's very random and will sputter but not stall. So far, I've put on new:
EGR valve
EGR gaskets
IAC motor
LIM gaskets
plenum gaskets
coils
ICM
ECM
CKS (both of them)
plugs
wires
cleaned the MAF (with MAF cleaner)
ohmed the injectors (all 12.7-12.9)
done a comp. test (150-160 in all 6)
checked for SES codes (none)
sprayed carb cleaner EVERYWHERE (no change)
Checked the timing (stock, belt is good, sprockets are where they should be)
Above 1000 RPMs it will go like a scalded dog...Below 1000 RPMs, it's
putt-putt-putt---putt-----putt--putt-putt and it has a very slight hesitation off the line. What makes me think it's a vacuum leak is that it gets worse with the A/C or heat on. But I can't for the life of me find it...HELP!
-S
EGR valve
EGR gaskets
IAC motor
LIM gaskets
plenum gaskets
coils
ICM
ECM
CKS (both of them)
plugs
wires
-S
