I have a set of 0 mile heads going on the car. Though they have no miles they have been sitting for years and the valve seats look a bit oxidized/tarnished. The valves going in are from a 120k mile engine. I plan on using a chemical of some sort to clean the valves before lapping.
Questions:
1) I plan on doing this by hand. Are the simple suction cup tools good enough? They have some cheapo's on ebay.
2) In the course of lapping I'll be sure each valve is used to lap a valve seat. However, is it important that the valve that laps a seat is installed into that seat?
3) Since the seats are presumably new, and the purpose of lapping is to just clean them up, should I stick with the finer compound or still start off coarse and then lead in to the fine stuff?
4) Since the valves have a good bit of use, how can I spot a burned exhaust valve or other kind of defect? Will it be obvious?
v6z24 has a decent write-up: http://www.v6z24.com/howto/valvelapping
Any veteran words of wisdom?
I'm planning on getting this done near the end of November and I'll likely take pictures to document removing the heads, disassembly of the valvetrain, lapping and reassembly.
Questions:
