I was just wondering if anyone around here knows anything about cruise control. Mine stopped working the other day. What should I be looking at?
Cruise control help
I doubt this is it if your's happened all at once, but ehre is what happened to me.
I know mine is a 5-speed, but the brake sensor is similiar. There is a plastic push button sensor right beneath my clutch and brake pedals. When either of the pedals is depressed, it pushes in the button and deactivates cruise control until button is released, at which time you normaly hit 'Resume Acceleration.' Now the button screws up or down about an inch to adjust it. My clutch one was screwed all of the way up, so the pedal was constantly depressing it so CC never worked. SO I disconnected the electrical thingy(pita) and screwed it all of the way in and reconnected it. Works perfect to this day!!!
Just a thing to check....
ok, I found the sensor you are talking about. Now this is the way it would appear to work to me. When my brakes are not touched, the button should be depressed (the sensor is on the seat side of the pedal, not the engine side) Therefor, as soon as the brakes are touched, the button will be released, kicking CC off. Am I thinking right?-=Danny=-
If that does not work, you could also have a bad vacuum line. IIRC, everyone that has the vacuum line problem says it's the one that goes between the vacuum ball and the cruise unit.-60v6's 2nd Jon M.
I just looked a little harder, there are 2 sensor buttons on mine. One right on top of the other, which one should I adjust? I tried to bottom one, but I can't get it to spin because the part of it where the electrical connections are made is too wide to get past a mount at one point.-=Danny=-
Mine quit working one day out of the blue. While in use. The cable that runs from the CC unit on the left inside fender to the throttle body slipped out of its mounting bracket on the throttle body. The plastic retainer had broke. The CC was doing its job trying to move the butterfly but couldnt. A simple wire tie keeps that bitch working now. Hope this is your prob cause its an easy fix.2004 Grand Am GT 3400 ... I had the right to remain silent, I just didn't have the ability.(Ron White)
Originally posted by bud36lightMine quit working one day out of the blue. While in use. The cable that runs from the CC unit on the left inside fender to the throttle body slipped out of its mounting bracket on the throttle body. The plastic retainer had broke. The CC was doing its job trying to move the butterfly but couldnt. A simple wire tie keeps that bitch working now. Hope this is your prob cause its an easy fix.-60v6's 2nd Jon M.
Originally posted by bud36lightYa gotta do what ya gotta do.................-60v6's 2nd Jon M.
