Wierd Grinding/Whining Noise From Engine
  • Question : Wierd Grinding/Whining Noise From Engine
    OK so here it is.. When in gear and on the brake and the A/C on with a load on the engine there is a grinding sound coming from under the hood.. As of right now the power steering pump whines and makes noises but the nosie is different.. It almost sounds like the ac clutch is turning on and off super fast.. The A/C blows cold but when in park and turning the steering wheel to the left and right and the hood open you can hear the ac clutch click on and off.. I was also wondering if the idler pulley for the accessory belt could make a noise like this.. I had a video but it deleted itself i will get another one tomorrow.. Also to add with the A/C on the whining noise sounds wayyy louder than a SUPERCHARGER.. Dont know what is going on here.. Hopefully someone can help..
    OK the video wasnt deleted..
    Robert
    New Rebuilt 3100
    New Rebuilt 4T60-E
    Exhaust
    Drilled/Slotted Rotors
    White
    3" Magnaflow Catback
    90 Pontiac Turbo Grand Prix
    5 Speed Swapped
    127,000
    Spec Stage 3 Clutch
    230,000 mile Getrag 282
    Emissions Deleted
    Brand new Engine 1,000 Miles
    Fully Custom Built car
    get one of them stethoscopes and check it out. Water pump can make a grinding noise. I had my P/S pulley whine like a super charger and it had a huge crack in it. A/C clutch could be about to blow up. etc.
      Water pump is brand new... Ill have to check for cracks... What about it being low on freon?
      Robert
      New Rebuilt 3100
      New Rebuilt 4T60-E
      Exhaust
      White
      5 Speed Swapped
      127,000
      Spec Stage 3 Clutch
      Emissions Deleted
        another video while driving..
        Robert
        New Rebuilt 3100
        New Rebuilt 4T60-E
        Exhaust
        White
        5 Speed Swapped
        127,000
        Spec Stage 3 Clutch
        Emissions Deleted
          low on refrigerant will make it not engage the clutch. That wine sounds like a pulley issue. Maybe the bearings are dry in the pulley somewhere. Check the tensioner for wobble/looseness on the pulley, and look for cracks/movement of the P/S pulley, etc etc.
          With the car off on mine you could press on the p/s pulley and see it wobble and see the crack around the center of it. I bought a $15 new pulley, pressed it off, and pressed a new one on with a puller tool.
            im going to check/ change the tensioner pulley before i get into changing the expensive/ hard to find power steering pump if the pump is bad.. thanks for the info
            Robert
            New Rebuilt 3100
            New Rebuilt 4T60-E
            Exhaust
            White
            5 Speed Swapped
            127,000
            Spec Stage 3 Clutch
            Emissions Deleted
              My pump wasn't bad, the pulley on it was. I just replaced the pulley and kept the original pump.
                the steeringg wheel stiffens up while making many turns into a parking spot..
                Robert
                New Rebuilt 3100
                New Rebuilt 4T60-E
                Exhaust
                White
                5 Speed Swapped
                127,000
                Spec Stage 3 Clutch
                Emissions Deleted
                  If it only does it in gear its possible its transmission related, i have heard transmissions make noise similar even while not moving, and when you are tuning the steering wheel and the a/c clutch disengages , that is normal because the powersteering pressure switch will shut it off to prevent the engine from stalling
                  Jake
