OK so here it is.. When in gear and on the brake and the A/C on with a load on the engine there is a grinding sound coming from under the hood.. As of right now the power steering pump whines and makes noises but the nosie is different.. It almost sounds like the ac clutch is turning on and off super fast.. The A/C blows cold but when in park and turning the steering wheel to the left and right and the hood open you can hear the ac clutch click on and off.. I was also wondering if the idler pulley for the accessory belt could make a noise like this.. I had a video but it deleted itself i will get another one tomorrow.. Also to add with the A/C on the whining noise sounds wayyy louder than a SUPERCHARGER.. Dont know what is going on here.. Hopefully someone can help..
OK the video wasnt deleted..
