I apologize, that diagram is from a later model.
More clicks than starts
ok, now that I have the car right you should check the positive cable provided all the connection and grounds you can find have been checked.
another slim posibility is a faulty neutral safty switch. The start signal form the ignition switch has to pass through the safty switch on its to the starter. But I'd go with the positive cable to start. though that more commonly causes the vehicle to continuously crank
Originally posted by wayfastwh1tey View Postit also contains the fuse which feeds the the ignition switch which, in turn feeds the the start wire on the starter. Look I've run into this problem before, and this it what solved it, so you want to dispute it have at it, I'm doneBen
When it does the clicking, beat on the starter with something heavy. Use a hammer or something. When mine did it while I was out and about, I used the factory lug wrench and it fired up every time after a good beating. That told me it was the solenoid on the starter. But yeah, I back up Sappys last post. The signal goes from the ign. switch to the P-N safety switch, then to the starter. So since the starter is clicking, everything before it is fine. I've been down this road too :P If it still does it after beating the starter like a rented mule, then I would check the cables for corrosion inside the insulation. The one on my 92 had it creaping down about 8-10" of the cable. Curiosity killed the cat and I kept stripping off insulation to see how far down it went after I replaced it.-60v6's 2nd Jon M.
AWWW KITTY!!!!!
I never had a problem with wiring just the starter itself... Intermittenly would not crank at all, as if there was no power getting to it, but there was.Lorenzo
