Hi all
The last two days i have been trying to get my montecarlo 3.4 dohc running fine, i change the timming belt , i double check the timming, changed spark plugs , new air filter , all vacuum lines checked and the idle continues very erratic, it looks like the cilinders 1, 5 and 6 are not working but the injectors seem working and i have checked the wires and looks good, to much fuel odor on the exhaust (when i pull the ignition wire there are no change) i take it to the shop for scan and just have the codes for oxigen sensor low response and pt low response, when i drive it to the shop on high rpms about 2000 to 4000 run good with good power
any help
Javcr
any help
Javcr
