I am confused about the tensioner actuator. The directions I have off of alldata say to clamp it vertical in a vice and let it sit for 5 minutes then retract the plunger and install the paperclip. I can manage to handle that. Then it says if the internal oil level is low fill it to the bottom of the hole with synthetic 5w30. I have tried that on two different actuators and on both of them the oil just pours out the end.
What gives? what is the procedure for filling the oil level and are both of my actuators bad?
