Oil Covered Spark plugs
  • Oil Covered Spark plugs
    My car has been running rough the past few days, so yesterday I pulled 2 of the 3 front spark plugs out. They had oil on the thread. From my understanding, this means eitehr the valve seal giudes are gone or oil is coming up from the pistons. How do I know what it definitly is? And how hard isit to fix?
    Thanks
    Jackie
    Its running rough because you made me put those POS bosch+4s in it. Told you to get declos!
    1994 Corvette
    LT1/ZF6
    2006 Dodge Dakota 4x4
    3.7/42RLE
      Or .. maybe you need to be more careful adding oil in
        Carrier/valve cover gasket and/or valve cover O-rings.
        severe>cam carrier gasket (upper cylinder head gasket)
        I am back
        Mechanical/Service Technican
          And I told you thats all they had. it was either bosch, bosch or bosch........
            The oil wouldn't even make it up to the threads if it were leaky valve seals. Wouldn't it just burn up and cause some carbon build up on the valves and spark plugs.
              yeah, if its the threads, its not the rings or seals, its a gasket issue. If the tip is oiled up, thats another story. Bosch sucks also.
                valve cover O-rings
                Valve cover <Keyword- Secondary> O-ring
                I am back
