The car is a 1995 Cutlass, 3.4 DOHC, 68,000 miles on it. The alternator was replaced 2 years ago and has about 3000 miles on it since then; battery is at least 4 years old. The car is stored during the winter.
The car has run fine until yesterday. But yesterday when I started the engine, the engine ran rough, and three warning lights were lit: ABS, Brake, and LOW TRAC. It sounded as though something was clicking under the hood - maybe an ABS sensor? I (probably unwisely) continued to drive, getting on to a 60 MPH parkway. As I got up to speed, the engine continued to stumble, the "Service Engine Soon" (SES) light came on, and I also noticed that the clock on the radio had been reset. Then there was a popping sound under the hood, the warning lights and SES light went out, the engine smoothed out and ran fine as I drove 12 miles home, including some stop and go traffic.
This morning I started the car and got the same symptoms as yesterday, the three warning lights lit, the engine ran rough. I shut off the engine and tried to restart it. It wouldn't even turn over, and all power to the car was dead. I checked under the hood, the battery connections seemed tight. When I got back in the car, I heard the "key in the ignition" chime going off, but at a very low volume. I turned the ignition and the car started, but still with the warning lights lit, and a rough idle. The clock on the radio had been reset, again, too.
I parked the car and will take a look at it this weekend. It seems electrical related, but that's just an amateur's guess. Any suggestions on how to troubleshoot this problem would be appreciated.
