Hey guys, So I think that the problem is when I let the car get cold or when I start it up in the morning the car has no oil pressure bacause the oil line for the turbo is coming off before the filter. This is causing the oil to basically drain out causing lifter tap as well. So if I put a check valve on the oil line, meaning that the oil only flow to the turbo and not back will this help with the starting. I know its not the battery as I can hear it cranking and its cranking good. It just does not like to start unless its hot. Then It will start right away.
Turbo 3.4 dont like to start- OIl Pressure?
