Timing gears question.
  • Timing gears question.
    '91 3.4L.
    The intermediate shaft and 'cam' gear have a keyway. I didn't see a key fall anywhere when I removed them. Is there a key?
    That's just GM trying to trick you. I looked all over my floor for the key the first time as well. There isn't one, but you can find a key at the hardware store that fits if you want to use one. The bolt is supposed to hold the gears together and to the shaft.
      This motor remains a mystery.
      Thank you for responding.
