now that i have the timing cover off i am starting to grasp that photo walkthrough. i see both of the casting marks the walkthrough was referring to i haven't seen the notch on the balancer but i am sure i will after i start turning the engine.i also see the flats.
the way this thing is works is these cam gears can lock and unlock allowing the cams to stay still while the gears and the crank to turn?
when i am turning the engine, which way am i going to turn it, clockwise or counterclockwise?
i heard u don't have to remove the gears or whatever
i have a 94 motor how do i lock and unlock the gears?
lastly, where do those homemade cam tools go?
