1995 Grand Prix GTP (3.4l DOHC)
I am in a bit of a pickle. Yesterday I replaced my water pump to solve a coolant leak issue, and have now noticed that the rad fans are not coming on.
The car runs consistently over the 100 degree Celsius mark (according to the dash gauge). I check both the fan relays and they are fine, fuses check out ok, and if I hard wire the fans they spin like mad. Also, the thermostat is functioning appropriately.
From what I have read, it could be a coolant (temp) sensor issue, but based on the schematics I have, there is only one temp sensor...but then I don't see how the gauge would be working and the signal to the PCM not be? Are there actually 2 sensors, and can anyone tell me where the two are? JP
