Fuel rail pressure
  • Fuel rail pressure
    Okay, key on, pressure rises steady to 41psi, then slowly drops back down, almost 10psi in 5 minutes. Engine running (idling), pressure remains at 39psi. Disconnect FPR vacuum hose, and it rises to 43PSI at idle. Any ideas?
    Okay now, that's enough of that.
    Normal.
    Is a bit high at idle check regulator???
    I am back
    Mechanical/Service Technican
      So.... 39PSI at idle w/FPR plugged in = too high? What should it be at?
