WARNING: Do not unplug your EGR without disabling it in the ECM. It will screw with the ECM. Any performance increase you think you get is in your head. Turning off the EGR makes no noticable increase in power, but will help you keep the power by not coating the intakes and intake valve with carbon deposits. I leave this thread here as an example of what an arrogant idiot sounds like. - SappySE107
Edit again. The only way you are gonna see a power increase from removing the EGR is if it was leaking. Then, a new stock EGR would give you the same results as removing it...other than your ECM is gonna be pissed at you for not disabling it. -SappySE107
I've been running my 3.4 ever since I got it 5 years ago, with the EGR valve unplugged. It makes noticeably more power that way. Has anyone else tried this ? I've done this with many previous cars I've owned as well, and they all ran better too. I see no reason to put exhaust gas back in the intake tract, from a performance standpoint.
