Ok heres the deal in the last two days I have done the following to my car...
Replaced upper and lower intake gaskets, replaced oil distribution cover gasket, replaced stock thermostat with the 160* one. I found four injectors that looked like they were plugged with some kind of gasket maker gooey crap (some chick dumped dex-cool into my gas with sugar).. I replaced those, I attached my cold air intake. I did an oil change and noticed that the oil was feul and anti freeze free. I changed the plugs back to the stock ac delco ones. Here's the delima.
When I drive my car the heat gauge stays just over the first notch. When I slow down or stop it not immeadiately but rather quickly climbs to half way between the third and the final mark (overheat)... the engine is unbearable to touch. I bled the cooling system correctly, I think... can somebody please list for me exactly how to bleed the cooling system on the z34. Its ripping me apart inside not knowing whats going on here.
When I had cap off (bleeding) tiny little bubbles would come to the top every so often, whats the deal?
Please help!
Please help!
